DIY: EK (96-00) Passenger Side Airbag Removal
*This is my first DIY, so be gentle with me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Note - Modifying, disconnecting, or removing airbag systems, components and/or hardware should only be done on vehicles used purely for race/show purpose only. In some countries, it is illegal to tamper or modify any portion of the supplemental restraint system (SRS). Please check with your local, state and/or federal laws pertaining to automotive SRS systems. Password does not assume any liability for damages resulting from the use of our Airbag trays. End users assumes all liabilities when using this product. Our Airbag trays are intended strictly for off-road racing use only!!!
Mounting requires the use of some sort of bonding agent such as double sided tape along the edges or a silicon adhesive. Removal of the factory airbag (SRS) should be done by a trained and certified professional who knows how to disconnect the battery and SRS control unit prior to any airbag removal. </TD></TR></TABLE>
- Courtesy of Password:JDM
Tools
- 10mm Socket & Ratchet
- Philips Screw Driver
Lets Begin
Step 1: Unplug Battery
*Remember to wait at least 5minutes before going ahead
Step 2: Remove Glove box
- i didn't post any pics of this cuz its easy to do, there are 2 screws under the glove box that u just unscrew and the glove box will drop
This is what it should look like so far:
Step 3: Locate & Unplug the "BOOM!" Wire:
Im not sure if this is true for all EK's, but it was for mine but the "BOOM!" wire or the wire that makes the airbag explode had this yellow tube stuff on it, but if u cant find it, it should be 2 red wires connected to a yellow connector. I found mine behind my radio.
Step 4: Start unscrewing the airbag from chassis
*I used a 10mm socket and ratchet
Step 5: Push that fu
ker out!
Fairly easy to do, just push the bottom of the airbag up and get a flat head screw driver and put it under the OEM airbag cover and push it up with that.
ITS OUT
NOW YOUR DONE
I didn't have my airbag tray cover yet, so i just took off the OEM airbag cover and push it back in its hole!
Hope this helped u guys out
this took me about 30-40min to do
Thanks To:
- Honda-Tech members
- HELMS
Modified by waterboy at 4:46 PM 10/13/2005
Tools
Lets Begin
ker out!Fairly easy to do, just push the bottom of the airbag up and get a flat head screw driver and put it under the OEM airbag cover and push it up with that.
ITS OUT
NOW YOUR DONE
Thanks To:
- HELMS
sorry, but personally I would leave it in. They really do work. if you ever get into a collision they could potentionally save your life.
the passenger side, kept my g/f from kissing the dash board.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Maybe it's my firewall at work.. But the pictures don't work.
Great write up though!
yeah it was hard to get good pictures cuz everything was compact, i tried to include as much detail as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill »</TD></TR><TR><TD CLASS="quote">sorry, but personally I would leave it in. They really do work. if you ever get into a collision they could potentionally save your life.
the passenger side, kept my g/f from kissing the dash board. </TD></TR></TABLE>
thats why u wear seatbelts
i installed 4pt harness after i wrote this write up, so i dont think the airbag will be needed anymore
</TD></TR></TABLE>yeah it was hard to get good pictures cuz everything was compact, i tried to include as much detail as possible.
if you want to install an aftermarket steering wheel .. once the driver side srs is disabled .. the passenger airbag will not activate whether or not it is hooked up or not .. so no point to have a passenger side airbag if you don't have one for the driver side ..
Did you know that most countries around the world have fewer airbags than the US? You know what they do instead? They wear seatbelts. There are more airbag injuries here than there are car accident fatalities around the rest of the globe
lol i was tired of the SRS light already, so i tried something... well it didnt work:
least to say, the light is still on
but you see where my thought process was
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Did you know that most countries around the world have fewer airbags than the US? You know what they do instead? They wear seatbelts. There are more airbag injuries here than there are car accident fatalities around the rest of the globe</TD></TR></TABLE>
i am sorry but your statistic sucks, INJURIES being the key word, these people are not DEAD! you can't compare injuries to deaths besides an airbag is good if you wear your seatbelts, it's by no means an alternative. also how can this even be relevant, what about all the countries where cars aren't the major form of transportation bicycle, motor bike, tram, feet. i am sorry and i don't mean to flame, i just would hate to have someone from H-T go out and quote this statistic thinking it was a good one.
Other than that very nice thread on removing airbag
i'm not saying airbags are good nor bad for the street ..
but for track use .. a full roll cage .. bucket seats .. harness .. a helmet and a helms safety device if you really want to be safe .. is the best ..
for street, you can argue both sides .. but for track . .we all know what's better ..
Take out the bulb on the cluster. Just removed mine 2 days ago and damn does it feel good to not have any unecessary lights on the cluster. It's hidden in a good spot but, tops 20mins to do. Nice right up by the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_ef »</TD></TR><TR><TD CLASS="quote">Nice write up but dangerous
lol thus the first paragraph
</TD></TR></TABLE>lol thus the first paragraph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waterboy »</TD></TR><TR><TD CLASS="quote">
i installed 4pt harness after i wrote this write up, so i dont think the airbag will be needed anymore</TD></TR></TABLE>
we were both wearing our seatbelts, but for some reason the locking mechanism that keeps the belt from moving didn't catch on her side. so she went flying forward. Mine did its job and I didn't move.
I hope you have some sort of cage that the harness is attached to. you'd be taking a serios risk by not mounting a 4 or 5 point harness correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">If you have no use for that airbag BLOW THAT **** UP! Run some wire about 100 from it and connect it to a car battery. Fun as hell
Or you could sell it for some money.
</TD></TR></TABLE>Or you could sell it for some money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jorsher »</TD></TR><TR><TD CLASS="quote">
Or you could sell it for some money.</TD></TR></TABLE>
This is the Best answer... don't be like this kid:
http://www.ebaumsworld.com/bottlebomb.html
30-40 min to remove 1 airbag... that's slow
Some B**ch removed both of my dads airbags in a fractions of a second.
If you drive that car on the street, keep the airbags.
It’s an nice and informative write-up
, but sacrificing safety over a dinky tray
