Reverse light backwards on 92 honda civic
Old Oct 12, 2005 | 09:27 PM
EGfosho's Avatar
OG Tech
Default Reverse light backwards on 92 honda civic
Well, after doing a tranny swap (5speed) my Reverse lights are backwards now. When i have it in gear or nuetral the light would stay on and when i have it in reverse the light would turn off. Some topic says the reverse light switch is on top with a whole bunch of wires coming out, but there is two. Does the reverse connect to the speed sensor or the other one with one wire coming out? I know i kinda fucked up the speed sensor because i lowered the tranny with the speed sensor on and two wires came off and one black wire stayed in and got stretch out. but i put the pins back in and the speedotimer still works.
Old Oct 12, 2005 | 09:42 PM
hatchi's Avatar
Default Re: Reverse light backwards on 92 honda civic (EGfosho)
check the wire that goes on the tranny itself
Old Oct 13, 2005 | 02:48 PM
EGfosho's Avatar
OG Tech
Default Re: Reverse light backwards on 92 honda civic (hatchi)
ya there is two, one on the left side(speed sensor) and one on the right side which i dont know? So what on the tranny will effect this backward reverse light problem?
Old Oct 14, 2005 | 03:03 PM
EGfosho's Avatar
OG Tech
anyone know?
Old Oct 14, 2005 | 04:10 PM
duggy's Avatar
The reverse light switch (assuming it's a 5spd) is on the front of your tranny near the vibration/torque mount. It has two wires coming out of it.
Old Oct 14, 2005 | 11:46 PM
EGfosho's Avatar
OG Tech
Default Re: (duggy)
thank you.
Old Oct 16, 2005 | 09:12 AM
EGfosho's Avatar
OG Tech
Default Re: (EGfosho)
Well, i looked at it and everything is connected and the wires seem fine. I probally better off just taking out the bulbs.
Old Oct 16, 2005 | 09:15 AM
hatchi's Avatar
try switching the wires on the connector to the tranny
guero2craze
Jun 4, 2007 05:10 PM
Civic4less
Jan 12, 2006 06:16 PM
mike93eh
Sep 29, 2005 02:01 PM
Dspad_91Civic
Jun 23, 2004 12:14 PM
DIYaccord
Oct 7, 2003 11:41 PM
