PLANNING TO CHAGE BELT/PUMP
Old Oct 14, 2005 | 10:18 AM
lv6l's Avatar
Default PLANNING TO CHAGE BELT/PUMP
hi i'm planning to chance my water pump and timing belt. i was wondering what do i need to buy, i know the water pump and belt, but do i need a new tensinor and valve selent or anything? thanks.
Old Oct 14, 2005 | 10:19 AM
snatch's Avatar
Default Re: PLANNING TO CHAGE BELT/PUMP (lv6l)
You shouldn't need a tensioner, you can replace it if you want to though just for peace of mind. I replaced my belt/water pump at about 83,000 miles and I didn't replace the tensioner. Other than that you should be good. I would soak the crank pulley bolt in PB Blaster for awhile before you start trying to break it loose.
Old Oct 14, 2005 | 10:21 AM
jameskersten1's Avatar
You could replace the tenn. but we dont normally unless its needed upon inspection (not often in my experience). When you install the water pump there is a gasket that you need to install with it so I put some silicone around the casing of the pump to insure it stays in the right position.
Old Oct 14, 2005 | 11:46 AM
THE GAME IS THICK's Avatar
Default Re: (jameskersten1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 &raquo;</TD></TR><TR><TD CLASS="quote">You could replace the tenn. but we dont normally unless its needed upon inspection (not often in my experience). When you install the water pump there is a gasket that you need to install with it so I put some silicone around the casing of the pump to insure it stays in the right position. </TD></TR></TABLE>
for sealant for the water pump, go to your loacal honda dealers parts dept. and ask them for a tube of HondaBond its the best thing out there!
Old Oct 14, 2005 | 11:52 AM
Default Re: (THE GAME IS THICK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GAME IS THICK &raquo;</TD></TR><TR><TD CLASS="quote">
for sealant for the water pump, go to your loacal honda dealers parts dept. and ask them for a tube of HondaBond its the best thing out there!</TD></TR></TABLE>
I work at the honda dealership and we dont carry that so...... good idea though for sure. I will bug the parts guys on monday when i am back from holidays
unhappy_idle
May 22, 2006 10:16 AM
antondaz
Sep 6, 2004 07:22 PM
91tegrals
Jan 16, 2004 04:13 PM
parasonic
Jun 16, 2003 06:26 PM
Chairman Kaga
Oct 2, 2001 12:33 PM
