Blinker flasher
Old Oct 13, 2005 | 05:48 AM
mjej's Avatar
Default Blinker flasher
Where can you get a blinker flasher? Also wheres it located to install it?
for 98 coupe
Modified by mjej at 10:15 AM 10/13/2005
Old Oct 13, 2005 | 05:55 AM
sicky's Avatar
grammer nawzi
Default Re: Blinker flasher (mjej)
What are you talking about? Hyper blinker? If you want a hyper blinker, just take out your front blinker bulb or the rear.
Old Oct 13, 2005 | 06:07 AM
IHateJDM's Avatar
Default Re: Blinker flasher (sicky)
you're probably just running low on blinker fluid.
Old Oct 13, 2005 | 06:16 AM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">What are you talking about? </TD></TR></TABLE>
Old Oct 13, 2005 | 07:16 AM
mjej's Avatar
good god, my blinker is blinking a million miles a on the left blinker. WHCIH usually means the flasher is dying from my understanding. And NO i don't want no hyper crap. I think it's called flasher relay or some crap like that.
Old Oct 13, 2005 | 07:19 AM
siregcivic's Avatar
the turn signal relay is in the fuse box under the dash.. get a chilton or helms
Old Oct 13, 2005 | 07:20 AM
mjej's Avatar
hmm maybe one of the bulbs is out on the rear the front is fine. I think that's what it means.
Old Oct 13, 2005 | 07:21 AM
mjej's Avatar
Default Re: (siregcivic)
where can you get that?
Old Oct 13, 2005 | 07:32 AM
hatchish's Avatar
you can get the blinker flasher deal from like any auto parts store and its located on the left under your dash get a manual and flasher relay but most likely its not the flasher unit they dont go out that often
Old Oct 13, 2005 | 08:05 AM
nocturnaldragon's Avatar
Default Re: (hatchish)
Under the dash on the left its mounted to the wall with a bolt going thro the top of it, you'll see 2 or three more relays in the same area depending on the options and yr of your car. Just remove them all. Aka take the 10mm bolt or nut out and slide them off so you can read the sides of them. One of them will say Hazzrd Flasher, simply unplug it from the harness and replace with a new one from any auto suply store and reasemble. Its pretty easy.
Old Oct 13, 2005 | 08:30 AM
mjej's Avatar
Default Re: (nocturnaldragon)
thanks man, Ima look in to it.
Old Oct 13, 2005 | 08:33 AM
JDM-97CX's Avatar
Default Re: (mjej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjej &raquo;</TD></TR><TR><TD CLASS="quote">good god, my blinker is blinking a million miles a on the left blinker. WHCIH usually means the flasher is dying from my understanding. And NO i don't want no hyper crap. I think it's called flasher relay or some crap like that.</TD></TR></TABLE>
No that usually means that you have a burned out bulb. Did you check to make sure that all of your blinkers are blinking?
And I don't know how you can say it usually means it is a flasher when you don't even know what or where it is.
Old Oct 13, 2005 | 08:35 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: (mjej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjej &raquo;</TD></TR><TR><TD CLASS="quote">hmm maybe one of the bulbs is out on the rear the front is fine. I think that's what it means.</TD></TR></TABLE>
Yes, that's what it usually means. If the relay is dead, they usually don't work at all. Have you even had someone/yourself stand outside the car and check to make sure all the parking lights/blinkers are working? If not, replace the bulbs and your problem will be fixed.
Remember to check the parking lights by turning them on to the primary position. I don't remember exactly how Civic bulbs are, but some Honda bulbs are dual filament. If one is dead, the car will "assume" the bulb is dead and give you that "hyper flasher" deal.
Old Oct 13, 2005 | 09:00 AM
mjej's Avatar
Default Re: (JDM-97CX)
I know the general idea about it. But for someone to make me look stupid and say oh ha ha change your blinker fluid is just ******* retarted.
Old Oct 13, 2005 | 09:02 AM
JDM-EJ1's Avatar
Check your blinker fluid.
Old Oct 13, 2005 | 09:12 AM
Slow EJ8's Avatar
Default Re: (mjej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjej &raquo;</TD></TR><TR><TD CLASS="quote">I know the general idea about it. But for someone to make me look stupid and say oh ha ha change your blinker fluid is just ******* retarted.</TD></TR></TABLE>
hey man lighten up
I would consider all of the blinker fluid comments to be making fun of the people who actually ask how they can change their blinker fluid, not someone like you who is just asking a question. Now your original question in the first post was very unclear, that is what prob sparked some of these comments.
Old Oct 13, 2005 | 10:08 AM
IHateJDM's Avatar
Default Re: (Slow EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjej &raquo;</TD></TR><TR><TD CLASS="quote">But for someone to make me look stupid and say oh ha ha change your blinker fluid is just ******* retarted.</TD></TR></TABLE>
you asked about the blinker flasher. that's why the blinker fluid was brought up. had you simply described your problem instead of referencing something that doesn't exist, we wouldn't have told you to change something that doesn't exist.
Old Oct 13, 2005 | 11:33 AM
DriftTheEg's Avatar
easy fix. probably just need a new bulb
Randy1121
Honda Civic (2001 - 2005)
18
Jan 10, 2014 06:48 PM
ergot
Jun 20, 2006 10:11 PM
ChrisHatchback
Apr 12, 2005 08:34 AM
Boosted96EK
10
Dec 10, 2004 08:52 AM
88civic4d
16
May 12, 2003 06:48 AM
