boost gauge question
any of yo have obx gauges? i tried to install them to light up at night but didnt work...it freaking **** me off.....i tried one ground wire and one constant 12v still wont work...any idea?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3k9civic »</TD></TR><TR><TD CLASS="quote">any of yo have obx gauges? i tried to install them to light up at night but didnt work...it freaking **** me off.....i tried one ground wire and one constant 12v still wont work...any idea?</TD></TR></TABLE>
what did you tap for the constant?
I had mine installed on a switch and it worked. When I did it from the radio, it was always on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3k9civic »</TD></TR><TR><TD CLASS="quote">so you hook it up with the radio? i tried that but it didnt light up</TD></TR></TABLE>
I wouldnt hook it up to the radio because then the backlight will always be on. Maybe its the bulb. If your radio works and the backilight doesnt work when it is tapped off the radio, then it may be the bulb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3k9civic »</TD></TR><TR><TD CLASS="quote">i trie the radio, strait battery, and even any constant 12v in the car..still doesnt work...this gauge doesnt use bulb!! it the night glow thing...</TD></TR></TABLE>
It doesn't matter. So it's like an "indigo" type of gauge, right? It should still work with a 12 volt power and a ground. If it isn't working, then the gauge is broken. Did you make sure the ground is a good one? Sometimes, you have to scrape a little paint off so it's contacting bare metal.
PrayingForDeath
Honda Civic (2001 - 2005)
22
Mar 28, 2008 08:05 PM
tyflip2
May 26, 2004 07:13 AM
