o2 sensor in different spot?
Old Oct 13, 2005 | 06:58 PM
d16vtecx's Avatar
Default o2 sensor in different spot?
ok my freind has a 97 EX stock motor
we installed some dc headers
his stock o2 sensor is on the upper half of the stock manifold
but the dc header has the o2 bung at the bottom of the collector near the cat
so we extended the wires of the stock o2 sensor to reach the spot on the header
now its throwing a cel
i havent checked the code yet but im pretty sure that's what it is
how can we fix the cel
should i get an o2 sensor from a 99/00?
thanks
Old Oct 13, 2005 | 07:10 PM
civic_976's Avatar
Default Re: o2 sensor in different spot? (d16vtecx)
i have the same problem mine is throwing a code 41 its better if you replace the o2 sensor
Old Oct 13, 2005 | 09:41 PM
specv5150's Avatar
check the wiring. That was my problem when I extended my oxygen sensor wiring
Civic98KH
15
Dec 10, 2012 08:26 PM
j3nniii
Oct 15, 2008 12:59 PM
wootcivic
Nov 29, 2004 10:01 AM
sackdz
Nov 4, 2003 06:40 PM
Phoenix_ITR
Jul 9, 2003 04:21 AM
