Need help!! running problems
Old Oct 13, 2005 | 06:07 PM
90dteg's Avatar
Default Need help!! running problems
I have a 95 civic hatch with an f22 accord swap non vtec. I'm running a VX hatch wiring harness. It starts and idles fine, drives fine until I hit 3500rpm and sounds like it is hitting the rev limiter and will not accelerate past that. Timing is set on the dot, fuel pressure and all. Any suggestions as to what it is? I'm running the accord ecu. the only trouble code I get is the o2 sensor.
Old Oct 13, 2005 | 06:36 PM
gsrHB's Avatar
Default Re: Need help!! running problems (90dteg)
i got the same problem with my civic hb i put a b16 in it and it does the same ****, i have no clue whats wrong, i would think its the settings on the ecu
Old Oct 13, 2005 | 06:41 PM
90dteg's Avatar
i've changed ecu's and it didn't fix it.
Old Oct 13, 2005 | 06:50 PM
sicky's Avatar
grammer nawzi
Default Re: (90dteg)
What you want to do is take large steps and make sure that you increase your leg speed until you can't move them any faster. I prefer left leg first then right, then left then right then left then right . . . and so on. Hope that helped.
Old Oct 13, 2005 | 06:51 PM
gsrHB's Avatar
well once again, i have the same problem and i need help, im only 16 years old and i did this jdm b16 swap all myself and im so close to makin this car work perfect but the freakin thing loses power at 3500rpm, im so frustrated damit
Old Oct 14, 2005 | 07:50 AM
90dteg's Avatar
I figured it out. my high rpm mode of the ignition control module is bad. need new ignition control module.
Old Oct 14, 2005 | 07:52 AM
90dteg's Avatar
Default Re: (sicky)
what is that mean? that it was a dumb swap. wait to see it run.
13g-crx
14
Mar 2, 2007 09:53 AM
ph0on
Feb 18, 2007 05:29 PM
ph0on
Feb 2, 2007 06:06 AM
wsriane
17
Jul 29, 2006 01:59 PM
_RedRiceR_
12
Jul 14, 2006 10:08 PM
