ok what happens when ur done with a clutch and u dont go anywhere in 1st gear
Old Oct 13, 2005 | 06:24 PM
Markb16a's Avatar
Default ok what happens when ur done with a clutch and u dont go anywhere in 1st gear
ok i just got done with my clutch and I put it in first and let the clutch out it dose nothing and dosent go anywhere some one said I had the clutch disc on backwards I replaced everything throwout bearing and the release bearing to. what do you guys think I know I am going to have to tear eeverything apart again tomorrow so what do you guys think.
Old Oct 14, 2005 | 05:29 AM
Mista Bone's Avatar
D Tranny Guru
axle not seated in the tranny......
Old Oct 14, 2005 | 06:04 AM
Cuda70's Avatar
Default Re: (Mista Bone)
Yeah, make sure your axle is all the way in. That's what it sounds like to me.
Old Oct 14, 2005 | 06:37 AM
.Ry's Avatar
.Ry
Default Re: (Cuda70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">axle not seated in the tranny......</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuda70 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, make sure your axle is all the way in. That's what it sounds like to me. </TD></TR></TABLE>
Old Oct 14, 2005 | 12:25 PM
T.J.'s Avatar
Would be the first Thing I would check. Sometimes there a bitch getting them all the way in. They may seem like there in but they got just a little more to go.
Old Oct 14, 2005 | 12:39 PM
siregcivic's Avatar
when you put the axles in.. slide it into the tranny get the hub put the axle in the hub put the axle nut on tighten it down with an impact... get the hub and slam it into the tranny.. dont use a hammer..
it happened to me when i replaced my stock with a stage 2.. got it done put the axles in got down the street to test it make shure everythings okay.. get ready to pull out into the intersection and the car stops right in the middle and just revs in 1st gear.. so i pushed it ( i thought the damn clutch blew up ) jacked it up on the side of the road saw the axle out.. took off the lca bolt and slammed it in..
Old Oct 14, 2005 | 12:46 PM
alleyezonme's Avatar
Default Re: (siregcivic)
does it click into gear?
Old Oct 14, 2005 | 02:11 PM
Turbo_y8's Avatar
Default Re: (alleyezonme)
when it doesnt move you call the tow truck and have it done by some one how does it for a living since you dont this hassle isnt worth saving 100 dollars for a clutch install
Old Oct 14, 2005 | 02:46 PM
TheNasty0ne's Avatar
Default Re: (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">when it doesnt move you call the tow truck and have it done by some one how does it for a living since you dont this hassle isnt worth saving 100 dollars for a clutch install</TD></TR></TABLE>
lol.
Hes learning!! we all want to be pro mechanics but arent. So keep your mouth shut maybe he cant spare a 100 bucks.
Old Oct 14, 2005 | 03:59 PM
Db1_77's Avatar
Amen to Skanky Bryan
Old Oct 14, 2005 | 04:12 PM
siregcivic's Avatar
Default Re: (hatch77)
if he doesnt learn... this could happen https://honda-tech.com/zerothread?id=1402940
why not learn how to work on your own car.. you take more pride in it when its done than have someone do it.. also a lot less downtime
Old Oct 16, 2005 | 05:23 PM
Being too worried about theft to have your car worked on by someone else is a pretty shitty reason to do the work yourself. You should want to do the work by yourself so you become self sufficient, save money, and know what you are driving! Your car could stolen at your own house so does that mean take it to a shop?
just re-check your steps, and make sure everything is plugged up enough... worst case scenario, you rip it all apart and make sure it is back together correctly! I guaruntee the next clutch you do you will remember whatever you forgot! Keep on wrenchin!
Old Oct 16, 2005 | 06:09 PM
7808's Avatar
who the hell installs a clutch for $100
Old Oct 16, 2005 | 06:24 PM
CoreyR's Avatar
Default Re: (7808)
i dont think you can even install a clutch disk backwards. i think the center spring assembly would hit the flywheel.
Old Oct 16, 2005 | 08:22 PM
7808's Avatar
Default Re: (CoreyR)
did you re attach the shift linkage? if you did maybe it came off
00-501itrspec
Feb 6, 2008 06:39 AM
crxricer66
Oct 31, 2007 02:59 PM
R.Kelley
21
Sep 29, 2006 08:20 PM
greddy13
Jul 4, 2006 05:24 PM
importdude2000
Oct 15, 2004 09:42 AM
