JDM RHD del Sol dohc vtec shift linkage in usdm sol
I'm in dire need of the right shift linkage for my gsr swap in my del sol, and i know that the only one that fits it is the del sol dohc vtec one.
now i have a chance to pick one up that came out of a jdm rhd b16 del sol and i need to know if it'll fit my application. is there any difference between the usdm del sol dohc vtec shift linkage and the jdm one?
Re: JDM RHD del Sol dohc vtec shift linkage in usdm sol (yesSIR-S)
anyone else confirm this? i was already scammed out of a shift linkage that some dude told me was a del sol dohc vtec and i don't need another headache.
Re: JDM RHD del Sol dohc vtec shift linkage in usdm sol (spunky424)
its the same shift linkage, you can also use integra linkage. i think any b-series dohc linkage will work
some Jdm linkage is gold, that is the only difference
Re: JDM RHD del Sol dohc vtec shift linkage in usdm sol (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">its the same shift linkage, you can also use integra linkage. i think any b-series dohc linkage will work
some Jdm linkage is gold, that is the only difference</TD></TR></TABLE>
You can only use a Del Sol VTEC or Civic CRX SiR (<--- JDM) shift linkage. The only gold linkage was found on the 98 spec ITR, and it will not work.
Re: JDM RHD del Sol dohc vtec shift linkage in usdm sol (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
You can only use a Del Sol VTEC or Civic CRX SiR (<--- JDM) shift linkage. The only gold linkage was found on the 98 spec ITR, and it will not work.</TD></TR></TABLE>
correct. so should i go for this jdm del sol VTEC linkage? it will fit my sol with gsr swap 100% right?
skiracer8148
03-17-2007 05:09 PM
SOLvtec
10-27-2006 09:30 AM
AzntaggeR
12-23-2003 09:34 PM
