clutch & mounts **help**
why does my car i have to press the clutch super hard just to get it started???and another question... what would be the cheapest mounts to use but reliable for my b18c1 into a 96ek? i was thinking the 99-00 si mounts would help? if i got it from honda
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">99-00 Si rear mount and B20Z timing cover mount.</TD></TR></TABLE>
The 99-00 si rear mount will bolt up to your old rear mount location, but also bolt to your new block.
The B20Z timing belt cover mount will bolt to the driver-side mount that is already in your car.
You want a presentation with graphs and charts?
Re: (Eran)
You want a presentation with graphs and charts? </TD></TR></TABLE>
yes please
yes please
Re: clutch & mounts **help** (gsr336)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr336 »</TD></TR><TR><TD CLASS="quote">why does my car i have to press the clutch super hard just to get it started???</TD></TR></TABLE>
because there is a switch on the clutch pedal that has to be pressed so you can start the car. its a safety feature so you cant start it in gear and drive through a wall/into a person.
Re: clutch & mounts **help** (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
because there is a switch on the clutch pedal that has to be pressed so you can start the car. its a safety feature so you cant start it in gear and drive through a wall/into a person. </TD></TR></TABLE>
probably but its rediculous cause i have to stomp the dam clutch like 10 times.. and hopefully it start..is there a way i can get around this? i never had to do this to any car but this dam car
