Need a walkthough on changine out fuel pumps
Re: Need a walkthough on changine out fuel pumps (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">Into a chevy celebrity?
Or a civic?
That kind of info is helpful.</TD></TR></TABLE>
Are you that retarded? He posted in the 92-00 Civic/Del Sol forum for a reason.
But anyway, its really not that hard, it took me about 15 minutes yesturday.
Remove the gas cap to relive the pressure.
Remove the back seats.
There is a cover with 4 screws on it, remove that.
There is about 6 10mm bolts holding the pump in, and the 17mm bolt onto. Remove that also.
Remove the return line clamp, and pull the pump out.
Then swap pumps, and re-install.
Or a civic?
Re: Need a walkthough on changine out fuel pumps (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">
I was making a point. And no I am not retarded.
A retarded person would assume that the process is the same for both 5th gen or 6th gen civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">I was making a point. And no I am not retarded.
A retarded person would assume that the process is the same for both 5th gen or 6th gen civics. </TD></TR></TABLE>
ooooooooooh dxcoupe he burned you bitch. TAKE THAT.
Re: Need a walkthough on changine out fuel pumps (ci_v_ic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ci_v_ic »</TD></TR><TR><TD CLASS="quote">
ooooooooooh dxcoupe he burned you bitch. TAKE THAT.</TD></TR></TABLE>
Not really. The 255 Walbro is pretty much the same install across the board.
Re: Need a walkthough on changine out fuel pumps (Red_EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM2 »</TD></TR><TR><TD CLASS="quote">Not really. The 255 Walbro is pretty much the same install across the board.</TD></TR></TABLE>
yea maybe the same install but not the same uninstall from 5th to 6th gen.
birds_sol_94
14
08-10-2004 01:15 PM
