brakes not working!
Old 08-19-2006, 11:09 AM
FastAzzCivic's Avatar
Default brakes not working!
Hey guys.
I just bought another 95 civic dx about a week ago and the brakes are horrible.
I have to press the pedal about 2 inches away from the floor if not to the floor for it to engage.
Any ideas on what is going on?
thanx ahead of time!
Old 08-19-2006, 11:14 AM
IVAN93EG's Avatar
Default Re: brakes not working! (FastAzzCivic)
bleed your brakes. you might want to buy new brakes and resurface your disks and drums also. does you e-brake go up very far. if so you need to adjust your back brakes
Old 08-19-2006, 11:17 AM
Default Re: brakes not working! (IVAN93EG)
I bled the brakes today.
didnt help any
Old 08-19-2006, 11:20 AM
professor poon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAzzCivic &raquo;</TD></TR><TR><TD CLASS="quote">I bled the brakes today.
didnt help any </TD></TR></TABLE>
take off your wheels and take a look at your rotors and calipers. does it make noise when u brake or is it just weak?
Old 08-19-2006, 11:22 AM
IVAN93EG's Avatar
Default Re: brakes not working! (professor poon)
are you losing brake fluid
Old 08-19-2006, 11:24 AM
I had to take off the wheels to bleed the brakes.
Rotors and calipers are fine.
Pads have normal small wear.
And about the fluid, no its full.
Old 08-19-2006, 11:26 AM
SVTPWD831's Avatar
master cylinder....brake booster......maybe....?
Old 08-19-2006, 11:27 AM
Default Re: brakes not working! (SVTPWD831)
I was thinking maybe the brake booster too.
How would i check that?
Old 08-19-2006, 11:28 AM
SVTPWD831's Avatar
yu got me there.....haha.....hopefully someone else will chime in....
Old 08-19-2006, 11:30 AM
Haha yeah hopefully.
I really need to get this fixed.
Im freaked out to drive it, i dont want the brakes to totally go out while im driving.
Old 08-19-2006, 12:11 PM
bumpp!
come on guys, i need help fast!
Old 08-19-2006, 12:12 PM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAzzCivic &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking maybe the brake booster too.
How would i check that?</TD></TR></TABLE>
apply pressure to the brake before starting your car. when you start it, your brake pedal should go down a little on its own. if it doesn't, bad booster.
Old 08-19-2006, 12:25 PM
Default Re: brakes not working! (thahuhstunna)
Alright i will try that monday when i get to work.
because my cars at work (i work at a body shop).
Any other ideas?
Old 08-19-2006, 03:32 PM
try that first and work from there
Old 08-19-2006, 03:37 PM
I will.
Thnx for the help guys.
Ill get bak to yall monday after i chek that.
Old 08-21-2006, 11:45 AM
hey guys.
checked the booster, not the problem.
since i work at a body shop, we have connections with a tire/suspension shop.
i took my civic over there and they are fixing what they can.
i did get news from them and they said that the rear brakes were locked up, and i will need to buy a new master cylinder.
Old 08-26-2006, 08:33 PM
update.
changed the master cylinder, then bled the brakes.
= fixed.
civiccpedx
29
11-28-2004 09:25 PM
See Are X
06-01-2003 02:51 PM
Quick Reply: brakes not working!
