engine mounts
engine mounts
I'm doing a swap right now... I got my stock motor out, after looking at my stock mounts they dont seem to be in good condition. I have new ones on the motor but I need 2 new ones that are located at the bottom that stabilize the engine. Not the whole mount just the buttom part that has the rubber.
What are they called and how much do they go for?
Re: (meagainsttheworld)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meagainsttheworld »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
you dont need a bump boosted rival just told you what to get.
Re: engine mounts (BOOSTED RIVAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVAL »</TD></TR><TR><TD CLASS="quote">Get energy suspension insert for it</TD></TR></TABLE>
so its better then the rubber stuff?
Re: engine mounts (meagainsttheworld)
so its better then the rubber stuff?</TD></TR></TABLE>
hell yes
hell yes
Re: engine mounts (ci_v_ic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Quote, originally posted by meagainsttheworld »
hell yes </TD></TR></TABLE>
can anyone confirm this?
HT White Ops
Urethane > rubber in every way. It's more resistant to degredation, vibration, tearing, etc. The only drawback with urethane inserts is that you feel more vibration in the car because the engine does not shift as much. But on the flip side of that, it helps with wheel hop because .... the engine doesn't shift as much.
Re: engine mounts (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Urethane > rubber in every way. It's more resistant to degredation, vibration, tearing, etc. The only drawback with urethane inserts is that you feel more vibration in the car because the engine does not shift as much. But on the flip side of that, it helps with wheel hop because .... the engine doesn't shift as much.</TD></TR></TABLE>
thanks
thanks
V8KiLLaTURBOef91
12-26-2007 08:12 PM
VTECcnIT
02-18-2006 08:05 PM
