No Spark + no fuel = no run. Help plz
I have a H22a swap into a 92 hatch. But here is the catch all fuses under the hood or under dash are good. Power to main relay but it doesnt click. tried that relay in another car workd fine. also did the same with the ecu. The car is throwing a hard check engin light. When the problem started i was merging onto the interstate and the motor flat out died. and suggestion or links to wiring diagrams would be helpful.
Bruce
Bruce
Re: No Spark + no fuel = no run. Help plz (3M TA3)
double check your wiring. also is the pump priming? i know you said the relay works , but maybe the pump is bad.
Re: (3M TA3)
sounds like the main relay could be bad or you have a wire that rubbed through and is shorting out on the body. Here is a quick test remove the main relay check each wire with a ohm meter to the chasis ground i think there should be only one wire that is ground. If you have more then one ground wire there is a problem
LowNSlow96ls
08-10-2014 07:32 AM
civic89si666
20
12-21-2009 10:25 PM
