92 eg8 d16z6 swap - VTEC won't engage
guys i've tried everything with this car please HELPPPPPPPPPPP!!!!!!!!!!!!!!!!!!
Vtec dosent wana kick in, i've clean the solenoid, change the seal, clean where it conects 2 and nutting (Vtec is wired to the computer suposely by the guy that did the swap) the car sometimes has trouble turning on and whn it does the idle is below 300 rpm and after like 10 seconds it makes a sucking noise(kinda of loud) and the revs stay at 1100 rpm. Please help i really wana fix this car i'm a die hard honda fan, this is my 3 honda that i have and all of the have always been well taken care off, kept clean. this one is like the black sheep of the family everything that i do to it for the good the car throws it back at me worse......
NEW PARTS
OEM water pump
Stage 3 cluth
spoon sports flywheel
OEM timing belt
Oil has been changed every 3000 miles or 3 months
PLEASE HELP ME WITH THIS ANY ADVICE WILL HELP
NEW PARTS
OEM water pump
Stage 3 cluth
OEM timing belt
Re: 92 eg 8 d16z6 swap problems
thats the second MAP sensor on it and the only thing that i havent checked is the wiring on it, and what about the problem whn i start the car, what can that be????????
A faulty MAP sensor/wiring can cause the high/rough idle you're experiencing. Is the wire harness stock from the car or stock d16z6? If it's stock from the car and it's a dx he would have had to wire vtec and the MAP sensor as it was originally firewall mounted like shown in my above picture. If it's stock from the d16z6, he shouldn't have had to "wire vtec" like he told you or the MAP sensor.
Vacaum leak?.. Does the brake feel normal. Sometimes the brake booster will have a internal leak and that will sound loud. Other than that spray throttle cleaner on the intake manifold so you can see if the idle changes. Be careful not to hit the distributor. Throttle cleaner plus spark = fireballs. Goood luck.
deam good point i never asked him that it must be the stock wire harness then ill have to check the wiring on vtec and map sensor... by any way u have the diagram for vtec?????
Here (d16z6 ecu is p28):
If you are running a p28/p30, this applies to you. It may work on other OBD1 ECU/engine setups as well, but i'm not promising anything. Directly from the solenoid you will need to run the green/white wire to pin A4 on the ECU, which is the VTEC Spool Solenoid Valve Control. Next, connect the orange/blue wire to pin D6, which is the VTEC oil pressure switch input. Finally, the black wire from the VTEC pressure switch must be grounded. If you are running a USDM p30, make sure you wire up your knock sensor to pin location D3, otherwise VTEC will not engage.
is a p28 and im gonna do that would be faster and more easy than check all the wires thanks a lotttttttttttttttttttttttttttttttttttt
Technical Hero
Re: 92 eg8 d16z6 swap - VTEC won't engage
Make sure the MAP sensor and TPS aren't switched around (they have the same style plug). MAP wire plug should be Yellow/Red, Green/White and White.
Sorry guys haven't been able to start working on the civic been really busy with work hopefully ill begin tomorow on it ill keep you guys updated
If you have CEL then you need to know what the light are telling you? YOu might have something plug wrong or not connected right..
guys map sensor is wired right in the engine bay, now inside the car is like a whole different world theres like 10 wires that i dont even know where are they coming from and to wich pin in the computer are they conected 2
Fighterinsnatch
52
04-10-2007 06:43 PM
88crxsi89
03-28-2003 09:56 PM
