B18B into EG - mounts, bracket(s), and axles
I'm gonna be throwing a b18B into my hatch pretty soon, and instead of buying nice aftermarket mounts or sourcing for used mounts, I've decided to just go to an auto parts store (Kragen, Autozone, etc) to get all the mounts, bracket(s) and axles.
I know I can get pretty much everything from an Integra, but I'm wondering what I need to ask for when I'm at the counter. IE, if I just told the guy I need them all from a '95 Integra, what are the names of all the mounts and bracket(s) that I need so he can pull them up on his computer?
Thanks.
Thanks.
Re: B18B into EG - mounts, bracket(s), and axles
I used engine mounts, half shafts, and accel cable from 95 Integra when I put B18 in my 93 hatch.
I think I used Civic trans mounts.
You'll need an OBDI P75 ECM from 94-95 Integra also.
Alright then.. here's what I got so far just from looking at the Autozone website:
tranny mount - http://www.autozone.com/autozone/par...30624_0_0_3498
rear mount - http://www.autozone.com/autozone/par...ntifier=130271
upper front - http://www.autozone.com/autozone/par..._195310_0_3498
lower front - http://www.autozone.com/autozone/par...4322_195318_0_
..and then of course the axles. Is that all correct so far?
the engine bay in the integra and the eg civic are almost identical im doing the same thing in my 94 hatch. you can get on ebay and get all the factory moounts that you need for round 70 bucks and you can use integra axles the hubs are identical as well...you have to change the hubs in efs thats why i chose an eg to do my build
make sure u have the mount BRACKETS from the integra. The trans torque mount bracket, the "rear T" bracket, the upper drivers side post mount bracket (by timing belt), and the driver side torque mount bracket.
yea but heres my problem, i have a b20 in my 92 eg hatch and it has the factory integra mounts..and the valve cover is hitting the hood and done made dents in it and also my radiator is hitting. why is my engine sitting higher?
oh i didnt know u had a b-series sitting in there already lol. should state that in your original post. but i don't know why ur hood is hitting. it shouldn't be. was your car an automatic at one time? also check if they put washers where the mounts are. i dont know if B20's have a higher deck.
Mixmasta
10
01-31-2008 08:43 PM
