HELP: I have a 2000 civic si blowing all cold air and no heat..
I know this topic has been covered many times, but cannot find my answer anywhere...I have a full 00 jdm type r swap(b18c). What can i do to try and fix the problem
Re: HELP: I have a 2000 civic si blowing all cold air and no heat..
1) Check whether the coolant level is low in the radiator and reservoir. Top off if necessary, and then bleed the cooling.
2) Manually turn the heater valve on the firewall heater hose to the full ON position to see whether this gets heat into the cabin. If so, your air mix cable may be disconnected or broken or the motor is bad.
fast+forward
01-29-2007 03:13 PM
