B18A1 into 95 civic - What intake should I use?
Old 11-24-2010, 06:21 AM
JoeyEGCoupe95's Avatar
Icon2 B18A1 into 95 civic - What intake should I use?
I want to put the B18a1 in my civic 1995. I have the complete wiring of engine b18a1 1992 automatic and the complet wiring of an engine b18a1 1995 man. the B18a1 1992 is an Automatic integra but a put a flywheel, clutch, etc.. On the Intake there was some differece with the intake of 1995 OBD1 and 1992 OBD1 and difference about EGR on automatic 1992. I juste want to know what Intake i Can fit on it, to have a normaly running of a B19a1 1992 Mnual ..? do i put the intake of a 1995 integra man.?! reste with the intake of 92 auto.?! put a intake of 92 man?! .. i don't know.. that my first Honda Swap ever.. At the moment my car as no engine and it was 1.6L VTEC SOHC automatic. I put a B serie inside , i have au omplet swap except my intake problem ... P.S. Sory for my English i'm in Québec city( Shawinigan) and i speak normally French, thanks for your answer .
Old 11-24-2010, 06:23 AM
Default Re: B18A1 civic eg
i have a manuel intagra trans with LSD SIR diff. for the civic, with **** rods of integra 92, and the tranny was a 1991( clutch wire )
Old 11-24-2010, 07:08 AM
NotAJDMFanBoy's Avatar
Default Re: B18A1 into 95 civic - What intake should I use?
You can use the Civic engine harness or the 1995 integra engine harness. Swap the 1995 intake on if it's off a manual trans car. You could use the 1992, but you'd have to rewire the IACV I think, and need to use the 1995 injectors or the injectors from your old motor.
Your alternator, starter, throttle body, etc are all fine.
Old 11-24-2010, 04:26 PM
OK thanks because the 1992 automatic Integra 's intake have other vaccum and EGR valve system, and not the manual version! . If i put a 95 intragra's intake it will still run normaly ..?! I have just Injector of b18a1 1992.
Old 11-24-2010, 04:39 PM
ifIexplode's Avatar
Are you trying to put an automatic B series motor in your Automatic civic? If so youve got a host of other problems besides what intake to use.
xkrntamax
03-09-2006 01:49 PM
Toolman
05-02-2005 11:02 AM
BADGUYNY
01-14-2004 08:10 PM
Quick Reply: B18A1 into 95 civic - What intake should I use?
