wiring issue please help!!!!
i have bought a jdm b16a sirII from hmotors to put in my em1. i have left the stock harness and ecu p2t. i have it all in place and it seems as the obd1 head only has one temperature related sensor so i have an extra plug. and my cfs is also there. but i have bypassed it by doing the de-pinning on the ecu side.
i'm still throwing a
code6
code9
can someone please help me? i have triple & quadruple checked my grounds and all my plugs. also all my wires seem in tact. the only thing is i do the old school thing about checking any fire out of my distributor and there is none. i can hear my fuel pump when i turn the key forward. for some reason i just have a spark issue. i thought it might be my coil but i swapped it out with the one the motor's distributor came with.
please help
code6
code9
please help
Re: wiring issue please help!!!!
someone help...
now its just throwing a code6, no spark. checked the ICM, coil and both test fine. went with the original distributor just in case the CYP was the issue, still no spark. all my grounds are in tact. i used my ground wires to ground my test light and check it with a positive, test fine.
how can i check my ecu? or what is the proper diagnostic for the ecu? or proper way to troubleshoot a no spark issue?
came to be the ign fuse under the dash... then i had obd2b wiring with the ckf sensor bypass running and obd1 distributor... which the obd1 distributor reads for the ckf sensor differently than the obd2 distributor... so i put my obd2 distributor back, with the ckf sensor bypass and started up on 3 cylinders
then i fixed it & its good
hondachris1994
08-15-2017 10:58 AM
Origin
23
04-23-2004 12:01 PM
