95 civic ex crank but no fire
Hey guys my girl has a 95 civic ex that is bone stock. It has a d16z6 in it and it has a problem with starting. She drove it one day and parked it at home went back ougt the next morning to go to work and it wouldnt start. It cranks over but it seems to be that its not getting any fuel. I know its not the fuel pump because i can hear it turn on. I really dont know what it could be as im not really a big honda guy lol. Anyways any help that yall could give would be greatly appreciated.
p.s. If you need any more information just let me know
Thanks
Thanks
Technical Hero
Re: 95 civic ex crank but no fire
You need to make sure its either not getting spark or not getting fuel. Take a plug wire out, hold the end against a metal part of the valve cover and have her crank it and look for spark. If it doesn't have spark:
http://techauto.awardspace.com/ignition.html
Could also be the main relay if you can't hear the main relay click when the check engine light cuts on for a second then cuts off while turning the ignition to accessory
http://techauto.awardspace.com/mainrelay.html
I know it's getting spark and I know the relay is working I checked the fuel filter to see if it was maybe clogged and it's not I have fuel in the rail but I don't know what else to check it's just weird because it ran great one day then the next it won't start could it be a crank or cam position sensor
skizman
08-21-2016 07:45 AM
