NEED HELP MY CAR WONT START (I SEARCHED)
I HAVE A 94 HONDA DEL SOL SI WITH A D16Z8 AND THE PROBLEM IS THAT THE OTHER DAY MY G/F DROVE IT TO WORK AND IT JUST SHUT OFF....I CHECKED THE BATTERY, ALTERNATER, STARTER, AND FUEL PUMP AND THEY ALL WORKED...SO I WAS THINKING IT PROBLEY THE DISTRUBTOR...CHECKED IT NO SPARK SO CHANGED IT AND IT FIXED THAT PROBLEM...BUT IT STILL WONT START..I ALSO DID A COMPRESSION TEST ON THE MOTOR AND 1 CYLINDER WAS GOOD IN SPEC BUT THE OTHERS WHERE KINDA LOW...I WAS CHECKING THE TIMING BELT AND IT WAS OFF TIME SO I AM GOING TO ADDJUST IT TO THE RIGHT TIME...SO MY QUESTION IS WHAT WILL CAUSE IT NOT TO START AND ALSO WAS THE TIMING PART OF IT???...PLEASE HELP...THANK YOU
Re: NEED HELP MY CAR WONT START (I SEARCHED)
if timing was off a little, it should still have at least sputtered or something. Start with fuses. Find out what exactly happened as far as if engine just quit, or everything stop working like guages, radio, etc.
Please turn off the caps lock function on your keyboard.
Recheck the cylinder compressions after you correctly set the mechanical timing. If any cylinders are still low, one or more valves were likely bent when the timing belt slipped.
I put a new timing belt on and made sure it was in the right way but still....No start im pretty much stump right now and dont know what to do...I hope it is not the valves...Any ideas anyone?????
TimCrxSir
04-04-2011 05:21 PM
89civicb16a1
11-19-2010 07:12 PM
