my fuel pump or my fuel pump relay?
I tried wiring a killswitch to my fuel pump from pin a7
on the ecu, although when i had my 12v constant power hooked to the switch which was connected to pin 30 i ran 87 to the green/yellow fuel pump wire.
it made this loud noise somewhere by my fuse box
and now my fuel pump wont turn on when i turn the key into ignition.
i realize now that i should have just connected the 87 to where a7 splice was
theirfore making constant power just go to the switch, switching the A7 pin
on and off.
my question is did i blow my fuel pump
or just the relay?
on and off.
or just the relay?
Re: my fuel pump or my fuel pump relay?
check to hear if u get the clicks from the relay if not then theres ur answer. also just a little advice next time just but ur kill switch some where along the power cable for the fuel pump and not pinned in the ecu i have mine hooked up like this and never had a problem in more then a year
94delsol6428
12-27-2006 07:06 PM
