Losing Power and MPG - 93 Civic Lx Sedan
I have a 93 Civic Lx Sedan equipped with a D15B7. I noticed that i am losing power and that my fuel efficiency is bad. I cant even drive shifting at 3k RPMs anymore, i used to be able to but now i have to shift at 4k just to drive same speed as everyone else, this is what i think is the cuplrit to why i have bad MPG. I drive till almost empty and fill up 10 gallons of 87 fuel, i get close to 200 miles per 10 gallons (20 MPG). Mileage is 166k, original engine, everything is stock except for an intake on a stock rubber intake pipe. What is going on and is there any parts i should consider replacing? What about my MPG, what could be done to get my 30MPG back?
Also i have driven it to 5k and 6k very often, and since it has been handed to me it was never abused like that.
Re: Losing Power and MPG - 93 Civic Lx Sedan
sounds like the cat could be clogged up, any cel's? It wouldn't hurt to do a full tune up with plugs, wires, cap, rotor, pcv valve, air filter and fuel filter as well.
You should be getting 30+MPG's with that motor/ chassis. Since the drivetrain is somewhat old I would start with plugs, wires, cap and rotor like Kista stated.
the principles are the same but I had a toyota once and the cat was clogged and going to work I had to go up this hill that I always did it in 3rd but had to downshift into 2nd gear.
Use only OEM recommended plugs, and OEM wires, cap, rotor and PCV valve. These OEM parts pay for themselves.
Ok so ill do a tune up, replace oxygen sensor, and maybe put a new cat. I had no check engine lights. I was wondering if i should seafoam my engine, or do anything to increase power without buying new parts because the car was bought for 1 grand.
92cb7sk8er
14
07-18-2012 12:03 PM
EG love
04-09-2012 04:32 PM
xiong28
14
12-07-2011 10:36 PM
Drifter721
12-15-2005 12:54 PM
