Soft Clutch (Clutch slave/mc prob?)
On my eg my clutch keeps going soft. If I bleed it it stays for a couple days then gets soft again, I'm not losing fluid, is there anyway to tell if its the clutch mc or slave? where should I start?
Re: Soft Clutch (Clutch slave/mc prob?)
I had the clutch replaced 3 or 4 years ago but have only driven 20k or so miles, the car was wrecked right after the clutch was changed and then parked for 3 years. The clutch mc and slave are new, probably 3k miles max. I didn't know as much about cars back then and I think I got screwed on the job, as the clutch makes a noise until I clutch in, then it stops, I've been told this is the throwout bearing, could this be the problem? I didn't think so because when its soft sometimes if I can just keep stepping on the clutch and the pedal will have pressure again.
did you put a block of wood behind the clutch pedal to keep it from hitting the floor while bleeding? if not you could judt have a screwed Clutch M/C
Seagull Management
You have a leak somewhere, master cylinder, slave cylinder or the line in between.
Seagull Management
Yes, sometimes if you depress the pedal all the way you'll get a piece of dirt in past the cup inside and score the bore of the cylinder, if its all new stuff though its unlikely. For what its worth i've always gone to floor when bleeding and never had a problem, not saying it doesn't or can't happen but I don't think its common.
There's a small fluid leak from the MC. This means the MC is suspect but unfortunately does not prove without a doubt that the MC is bad.
