ej1 with b20 won't start
ok i got a ej1 wit a b20 swap cranks over but no start, changed ignition module still nothin changed to obd2 distributor wit obd1 ignition module new plugs but crank over no start or no spark...
any ideas...
any ideas...
Re: ej1 wit b20 wont start
no spark, its weird cuz i just drove it home, put in some sub s and amps then all of a sudden no spark or nothin, three hours earlier it was runnin perfect. i went to thhis auto store in sac, they replaced my ignition module twicve but still no spark or nothin tested to see if there was power goin to the distributor and there is so he threw me a obd2 distributor i spliced the wires so harnesses plugged in and put the obd1 ignition module in it and still nada!
Re: ej1 with b20 won't start
u neeed a obd1 distributor on obd1 motor the injector pulses and everything are different.. chances are if u have no spark it would be something in the distributor, had same prob with a dc4 changed coil, and a few other pieces in dizzy and turned out it was bad.. autozone had it in stock for 200 cash .. lifetime warranty but u still need a cap and rotor
sorry for winded post hope it helps
yeah im pretty sure it primes you mean when you pturn the key and hear it like engage, and i got a auto ex cluster when i got the carand the cel come on when the gas is low but i think it still comes on when its cupposed to so imma check for a code and let you know
Travis Davidson
07-25-2017 07:11 PM
Jonathannx2
06-02-2011 09:48 PM
B16A CRX
11-23-2007 09:25 AM
