help needed.. ac compressor bracket?
i have a 95 ej1 that had a gsr swap .. and know im putting a jdm d15b in it and want to still have ac and everything.. so is there a bracket so i can use my gsr ac compressor with the d series? iv searched and found nothing
thanks
thanks
Seagull Management
Re: help needed.. ac compressor bracket?
Did your GS-R swap use a B-series compressor? Normally most people just run the D-series compressor with a Del Sol Vtec or CR-V A/C bracket when they do a B-series swap.
it should be reverse. you should be using the civic compressor in the gsr swap and using the dohc vtec del sol bracket or the crv bracket. are you saying you are taking out the gsr and swapping a d15b?
yea its a b series compressor.. the motor blew this past week.. rod let go of the wrist pin and you know the rest haha.. but i have a d15b on the way. id like to still use the b series. its still charged and just zip tied up in the engine bay. i know you can use a d with a b using the delsol or crv bracket but can you use a b on a d?
Propulsion
08-12-2002 10:13 PM
slowpokesi
17
07-20-2002 08:31 AM
