Alternator Working/Whats the Problem?
1997 civic w/ 1997 itr motor
problem: battery keeps draining
tested all fuses and they are working/test wit test light
tested my alternator at auto shop and it is good
battery is still draining, so what should i test or look at to fix the problem
Re: Alternator Working/Whats the Problem?
Is the alternator working in the car? If not, did you check fuse 15?
Have you checked for parasitic drain?
Disconect battery and wire test light up to battery and disconected lead then start pulling fuses one at a time,when light goes out you have normally found the circuit with the problem.
car off = 12.5
car on = 14.08
car on wit high beam and heat on max = 13.6
is this a good sign? is battery recharging again?
Get a test light, take off your negative terminal, hook up your test light between your negative terminal and your battery post. Make sure there is nothing on or it will give you a false test, if your test light, lights up then you have a draw somewhere.
nikez4me
07-12-2011 04:48 PM
