Need help with B16 Motor swap in 92 Civic EX Coupe
Re: B16 Motor swap in 92 Civic EX Coupe.
B16 in an eg? Never been done before.
Anyway, stock mounts will work, you just need the rear t bracket, lower torque mount brackets, ecu (p30), axles, half shaft, shift linkage, your stock engine wiring will work, you'll just need to add 1 wire for the knock sensor.
Side note...are you sure your car is a 92? Coupes were not available until 1993.
Re: Need help with B16 Motor swap in 92 Civic EX Coupe
I haven't run any torque mounts in 2 years. As long as you're using upgraded mounts for the engine and tranny side, you should be good.
