Hondata heatsheild gasket fits weird on my d16 IM[PICS]
Old 11-20-2010, 01:26 PM
jonesEK's Avatar
Default Hondata heatsheild gasket fits weird on my d16 IM[PICS]
Alright I bought a hondatat gasket for a d16 from jhpusa for 49 + tax....
Problem is the gasket doesnt really line up to the intake manifold holes correctly..
looks like there will be some slight modification needed... It clears where the "air" is suppose to run thru but where the fuel squirts out doesnt look too good.... either way its going to neeed modification to fit properly
honestly I'd just rather return it (try to) to jhp which is a 30min drive or to hondata if jhp refuses the return since the package is open. I cant call either company today since theyre closed weekends FML
Final thought... I shoulda went with the bisimoto it would be impossible to mess up a D gasket for him right?
I noticed bisimoto's gasket is similar with the holes inverted and 1 leading to nowhere... anyone wanna speculate?
Bisi's pic from his site
^IDK what engine its for^
hondata only has 1 model? for the d16 and
bisi has 4 different ones.... 1 for d16, d16y/d16y8, d16a1, d16a5/d15
anyone else have a similar problem??
Old 11-20-2010, 01:39 PM
ekb16's Avatar
Default Re: Hondata heatsheild gasket fits weird on my d16 IM[PICS]
looks like its the wrong gasket
Old 11-20-2010, 03:47 PM
jonesEK's Avatar
I found a pic of a bisimoto gasket from some user online
BUT its hard to tell if its the one i need >.<
Old 11-20-2010, 03:49 PM
H22AFerio's Avatar
no its the right one IDK what that hole is for its not used but the OEM gasket has on to, Take a look But the injector part looks a little weird tho..?
Golden Eagle Has the same thing also
Old 11-20-2010, 03:52 PM
jonesEK's Avatar
^ thanks man... why does it fit so shitty!?!.... its just bad... im extremly disapointed i planned to have my IM on this weekend
and whats up with the hole in the center?? i saw my gasket has it and also the one u posted... wouldnt heat get thru there "theoretically" same for the one near the coolant hole
:EDIT is taht an aftermarket manifold or stock??
Old 11-20-2010, 03:54 PM
95civickilla's Avatar
its diffrent the d series gaskets when i rebuild my engine the gasket kit came with 3 diffrent kinds of IM gaskets i think the vx,cx are the same and the dx/lx are the same and the ex trim is diffrent so i know that for experience the intake manifold for the d series 92-95 are diffent even for the ek too
Old 11-20-2010, 04:08 PM
H22AFerio's Avatar
As he just said all the gaskets are a little different, I think they might have made one that fits all the models to cut down on cost. as for heat leaking through I don't think that will happen at all becaus the manifold is not close enough to the head to transmit that much heat. These gaskets work wonders on cuting down intake temp.
Old 11-20-2010, 06:27 PM
jonesEK's Avatar
yeah Im guessing thats what they did too... But if your going to charge an arm and a leg (TO ME IT IS!) for a gasket you should produce them correctly... If not then you will not be selling many gaskets that dont fit...
SHOULDA GOT THE BISIMOTO!!! FAWK!
Old 11-20-2010, 09:19 PM
NotAJDMFanBoy's Avatar
You should just get a Dremel tool. I made a heat shield gasket out of a sheet of Teflon I bought on Amazon. It was $30 for a big sheet, and I got enough to make 3 intake manifold gaskets and at least 3 throttle body gaskets. I was going to make at least one for someone else, but they're being a tool.
If you don't have access to a Dremel, use a knife and try to cut away what you don't want. That gasket is pretty close.
Old 11-20-2010, 09:43 PM
jonesEK's Avatar
yeah i saw other people on another forum doing the samethhing i forgot what material they used but they made TB/IM heat sheild gaskets....
Im just disapointed, i bought this thinking it was a direct install w/ no mods.
Old 11-20-2010, 10:28 PM
H22AFerio's Avatar
its all good bro it already said and done. we learn from our mistakes.
Old 11-21-2010, 05:43 PM
jonesEK's Avatar
bump any one else have the same issue before i try returning it with a JHP 25% ($12.50) restocking fee
Old 11-21-2010, 09:22 PM
Well, there are other phenolics, but Teflon is the best for this since it will have some give so that it can seal and it's a better insulator...but it's expensive.
It will install it looks like, just it isn't perfect. You could get a little file or a knife or cheap rotary tool. I know it stinks grinding on something new, but it happens.
The Hondata gaskets are known to leak. So if you do use it, you either need a gasket on either side, or some sort of sealant.
Old 11-21-2010, 11:08 PM
jonesEK's Avatar
Damn Fanboy i tried researching (which i FAILED at) about the gaskets before hand... Do you happen to know if the bisimoto gasket is any better? as in doesnt leak
Old 11-24-2010, 12:43 PM
cbustuner's Avatar
That round hole that goes no where is for the egr port on the cylinder head.Even though most usdm civic's (other then vx/hx maybe cx?) don't have an egr valve on the manifold they still have an egr port in the head casting.The intake manifold basically blocks it off The square hole is for coolant.They are suppose to be there.
The reason the ports seem weird on your gasket against your manifold is because hondatas gasket must be designed off the 96-00 coolant port because it's square. The 92-95 coolant port is round. I have a golden eagle gasket that is the same way as the hondata gasket on a 93 ex head and it sealed there fine.
M2B4
10-13-2007 06:42 PM
GSR4U2NV
11
05-22-2005 08:04 PM
bushfreakz
10
10-02-2004 03:20 PM
ImportHatch
05-24-2002 06:54 PM
Quick Reply: Hondata heatsheild gasket fits weird on my d16 IM[PICS]
