Bad Headgasket?
Bad Headgasket?
Took off my valve cover to check something earlier and found this:
http://img230.imageshack.us/img230/7295/33600347.jpg
http://img262.imageshack.us/img262/6418/76633870.jpg
Now I don't see any milky colored oil on my dipstick, nor do I see oil in the coolant. Could it just be condensation from sitting in the cold (Don't have a heated garage and it gets pretty cold here).
Re: Bad Headgasket?
id say the headgasket may be gone.. my eg smokes like a masquito fogger (white smoke), and my oil looks like chocolate milk, but ive drove it thousands of miles trying to blow it up when it does the y8 goes in
Re: Bad Headgasket?
Re: Bad Headgasket?
Well was trying to get the oil cap off of the valve cover, but it was pretty tight so I had to take the valve cover off to spray the cap with WD40 to help a bit.
That's when I noticed that milky substance.
Re: Bad Headgasket?
the only 100% way to tell is going to be to take the head off the motor. my headgasket blew about 3 weeks ago and my oil and coolant looked perfect with no smoke.
Re: Bad Headgasket?
try spraying some wd40 in some extra oil you have laying around and see if it gets "milky". Maybe, hopefully you just got a lil wd in your oil. Also you may very well have condensation in the exhaust. That would be white smoke but would evaporate into the air. If there is white smoke that you can see fallowing you down the street then you may have a prob. How is the engine running btw, have you checked compression?
Re: Bad Headgasket?
Last time I checked the compression which wasn't too long ago I had:
Cyl 1: 230
Cyl 2: 220
Cyl 3: 220
Cyl 4: 220
JDM B16a/GSR Head
It drives fine, only at idle does it make a small popping sound from the exhaust (Could that be from the somewhat decent sized hole I have in the pipe welding?)
But other than that, it's fine.
Cyl 1: 230
Cyl 2: 220
Cyl 3: 220
Cyl 4: 220
JDM B16a/GSR Head
Re: Bad Headgasket?
An old friend had the same thing in his Type R. It was running rich.
Plus, he drove the car in and out of his shop every day. Without running it to the proper operating temperature.
I would continue to investigate, just to be sure.
Re: Bad Headgasket?
Did another compression test after driving it around for a bit
Cyl 1:210
Cyl 2:213ish
Cyl 3:210
Cyl 4:210
If I had a bad headgasket, wouldn't I get lower numbers?
Cyl 1:210
Cyl 2:213ish
Cyl 3:210
Cyl 4:210
Re: Bad Headgasket?
It might not detect a leak between coolant and oil passages though.
I had ok compression readings but yet had exhaust in the radiator (blown head gasket or a crack).
I'd try this test before pulling the head.
Re: Bad Headgasket?
Re: Bad Headgasket?
i had literally just replaced the upper and lower radiator hoses, coolant flush, and new thermostat, and then a few hours later my car started to overheat while i was driving. also, i pulled the spark plug out of the #1 cylinder and it was cleaner than it was new (it had about 5k on it) while the others were starting to get dirty.
