RSX Type S muffler on an EG?
My girlfriend has an 03 RSX Type S, and we just got her a Tanabe exhaust, my Question is anyone ever put a OEM Type S muffler on their civic? I just want something w/ more breathing room and still stock/sleeper looking.. was thinking of doing mandrel bent piping the rest of the way back, any thoughts?
Re: RSX Type S muffler on an EG?
i don't know about the 03 but i got a 06 type S on my hatch and i have to do some mods. to make it fit. it still stick out about 2in and the canister is almost hitting the LCA. other then that it sound nice and quite.
http://i150.photobucket.com/albums/s...after/0015.jpg
http://i150.photobucket.com/albums/s...after/0016.jpg
It does sound very nice, and even flows very well.
I got a EP3 muffler, and was quite impressed with it ( went from a stright through aftermarket model to this ) .
Might sell the dual tip muffler for a RSX muffler to get a single tip, The eps is still flashy but quiet !.
it definatly is not a straight bolt-on application,hell I needed more than 1.5 ours to make it work but yes it did perform very very well but the +05 is even better (its a little different,it has valve inside like corvettes do and is free flow when on hard throttle yet very restrictive for low noise when on part throttle)
my installtion too had the exhaust tip stick out alot so what I did was I cut the tip right off,I mean I had a flush surface on the canister and then I cut the tip in half and welded the tip back onto the canister and ended up with a very clean nice look
on a coupe the axle back is 100% bolt up. not sure at all about on a hatch or 4dr. but i wil vouch again for the excellent sound.
On a hatch it needs to be modified ( shortened ) a bit to fit correctly.
any muffler shop will do this in 10 minutes.
Had the local shop do it to the stock B pipe and worked great.
Then had him do a custom 2.5" cat and EP3 muffler and works great.
i have an 04 type s muffler, the tip sticks out a bit but sound good, & the canester is pretty long so the tip pokes out a lot
TrackSpeedRacing
11-25-2008 05:28 PM
