97 y8 block on a 99 y8 vtec head?
Old 12-16-2009, 05:25 AM
vital123's Avatar
Default 97 y8 block on a 99 y8 vtec head?
Okay i know this has been talked about in the past, But i have a 97 block and im looking to put a y8 vtec head on it. What do i need to make this happen? Thanks
Old 12-16-2009, 05:40 AM
WeakSauce92's Avatar
Default Re: 97 y8 block on a 99 y8 vtec head?
wouldn't it be a direct swap? maybe some wiring for vtec?
Old 12-16-2009, 05:49 AM
vital123's Avatar
Thats what im trying to figure out.
nomoshing's Avatar
both Y8 man same exact thing good to go
Old 12-16-2009, 06:15 AM
I guess the 97 didn't have vtec? then you'll just have to do some wiring from the ecu up to the head. and I'm sure other little stuff. just look up mini-me or something.
Old 12-16-2009, 09:20 AM
justlook's Avatar
96-00 has vtec...and also doesnt have vtec...depends on the model you bought. duh.
if you originally had the harness of a y8...it should be plug and play or well bolt on and drive.
Old 12-16-2009, 12:27 PM
vital123's Avatar
So i need a y8 harness for the head.. Would i need a different ECU? I still have my stock ECU from a 97 dx hatchback.
Old 12-16-2009, 12:33 PM
itsnotfast's Avatar
You will need a P2P ECU to just plug and play. You will also need to wire up the V-Tec solenoid. It would be WAY harder to replace the harness because it goes through the firewall. The head will bolt up just fine.
Old 12-16-2009, 12:46 PM
vital123's Avatar
Alright Thanks.. a P2P ECU from a 99 EX Civic will work fine?
Old 12-16-2009, 12:53 PM
99EeeKay's Avatar
yes, assuming your 5 spd and so is the ecu.
Old 12-16-2009, 12:56 PM
vital123's Avatar
Okay Thanks
assassinACE12
10-24-2007 01:32 PM
The Collin
02-26-2007 03:59 PM
diewnaylomoah
13
02-16-2007 06:56 PM
T25 civic
09-06-2002 06:45 PM
Quick Reply: 97 y8 block on a 99 y8 vtec head?
