obd1 to obd2 wiring problem
I have done an 96 ls obd2 swap into my 95 civic obd1 i used my stock civic engine wire harness i converted the distributer to the obd1 i got to the IAT sensor which my stock harness does not have so my first ? is how do i go about fixing this problem. I have the ECU for the LS. My next ? is the alternator plug is differnt from the one on the LS motors alternator what is the best solution for this i tried using the alternator from my civic but it didnt line up with the LS bracket. Last ? would it of been alot easier to have gotten a LS wire harness and did it that way.
Seagull Management
Re: obd1 to obd2 wiring problem
Without the OBD2 Integra harness you will either have to cut and splice plugs or use an OBD1 LS distributor, OBD1 injectors and an OBD1 B-series alternator.
Pics of OBD2 Integra harness in a '92 - '95 Civic:
i have a obd2 harness from a 96 inegras ill be happyto sell if yo need one. i had to use my harness in my car since its obd2, id be happy to help you out
topshotta
03-21-2010 10:58 AM
Hybrid EG Hatch
02-06-2006 06:10 PM
