Need help with part #'s
I need the part #'s for the bolts that connect the trans to the Block, I have the #'s for the 2 that connect the stiffeners to the trans and block, I believe that leaves 6 bolts. I checked hondapartsunlimited, acuraautomotiveparts, and hondaautomotiveparts, but no luck. I don't know if I am looking at the wrong section or just overlooking them, any help would be appreciated
TIA
TIA
Re: Need help with part #'s
bump for year and drive train details. VIN would be idela if original drive train is in. If you are talking about a B series look up a 95 del sol VTEC
Anything wrong with a trip to the dealer? You could always say I need a printout because my mom is gunna buy for xmas.
Crazy Honda Guy
why not stop by a local Honda or Acura dealer, they will have detailed pics and either have the bolts there, or get them in a day
thanks again
Ok, went to the dealer and he had the same diagrams that you get online, he was not able to order the part or even find the part #'s. He said he had the same problem when he tried to order them for someone else and he even called acura and tried to get them from them, still no luck.
If anyone works or knows someone at a dealer or shop that can get the part numbers it would be greatly appreciated if you can get the part #'s for me. If your swaping out a clutch or motor anytime soon and you canmeasure the bolts that would be great to, then I could just go to the hardware store
TIA
TIA
UPDATE
they were listed in the helms as 12x1.25 but no length I ended up using grade 8 bolts that were 12 x 1.25 x 70mm
www.hondapartsdeals.com you can get the PNs from there... Since its a B16 you have look at the 94 DelSol VTEC model which has the B16A3. I hope this helps, I'd get you the part numbers myself but I'm doing this from my BlackBerry and it would be a pain in the *** to switch back and forth between HT and that site to get the numbers for ya.
