ek sideskirts on eg
ek sideskirts on eg
hey wats up guys
well i seen the ek sideskirts on some eg's
i was wondering if any of u guys know some details like if it bolts back in like the eg?? or are the ek sideskirts longer??? or any details
ill probly put some ek sideskirts on my eg it looks pretty clean
but i wanna get the heads up first....
Re: ek sideskirts on eg
Did you search anywhere one here?...Anyway I did this long time ago.
The Ek skirt is longer. I wanted to save the flair at the back, so I cut off the front.
From what I remember, only on or two of the white clips line up.
You probably would want to practice on crappy ones first. Or get someone who has done it before.
You just have to be creative. G/L with that.
i tried searching but i couldnt find anything
well i guess ill be doing that soon yeah thats what i like the flare at the end so yeah ill just cut them from the front it be a good lil project i think hah well thanks
This sucks without pictures, unfortunately I don't have any now.
Since you are going to do it yourself, here's a little description.
-I cut the skirt from the front 1 inch longer then needed, slice the FRONT CORNER of the skirt inward 1 inch.
-Then using a heat gun I folded the bottom piece/tab upward.
-Then the side piece/tab inward, creating a cap on the front of the skirt.(kinda like the back)
-Two small screws to prevent it from splaying open and your set
-Like I said in my last post. I think the last clip will line up.Not sure though?
-I drilled new holes along the bottom, to match the body holes.
-The front fender liner assists in holding up the front.
I'm sure I have forgotten some details. You have to figure some things out as you go along.
Hope this helps.Cheers
RosaTookMySeat
18
06-18-2012 04:52 AM
