Jdm OBD0 b16a into OBD1 Eg Hatch Questions
Ok so first b series swap got some questions, Heres what im working with:
Jdm OBD0 B16a Cable LSD trans into 1994 Civic dx hatch.
First question: Because the car comes hydrolic do i ABSOLUTELY HAVE TO buy the hasport conversion kit or is there another way?
Second: Also do i have to buy the OBD0 to OBD1 conversion for the ecu ?
thanks
thanks
Re: Jdm OBD0 b16a into OBD1 Eg Hatch Questions
On the first one, to use a cable trans youll need to convert it to hydro (whether it be a hasport kit or whatever). For the second, i would imagine you could just get a ob1 intake manifold,sensors, and harness and just make it obd1?
Technical Hero
1. Use OBD1 ECU (P28 chipped, P72 chipped, P30)
2. Use a B16a or B18C distributor (can't use OBD0 dizzy with an OBD1 ECU)
3. Use some OBD1 injectors from anything but a CX or VX hatch
4. Use a OBD1/2 B16A header
5 If not an EX or Si run wiring for the VTEC solenoid, VTEC pressure switch, and knock sensor (you'll have to add knock sensor regardless what model it is).
6. You'll have to use an OBD1 throttle body with a MAP sensor on top or grab a wall mounted MAP sensor and mount it in your bay somewhere.
7. Run wiring for the fan switch to the back of the block where the OBD0 fan switch is.
I don't really have an answer more a similar question.. I have pretty much the same set up b16a obdo Im looking to throw it in my eg hatch i also have a gsr typeR tranny
I have actually already ran vtec wires Im currently running a d16y8 vtec swap but trying to step up
Any help would be much appreciated thanks
Posted from Honda-tech.com App for Android
VTEC_Honda
06-01-2011 03:54 PM
