b swap shift linkage problem
hey guys i have got a 93 del sol and i am doing a b18b1 swap and here is the problem i have motor, tranny, gsr rear bracket, dc front mounts, and vtec or bseries del sol linkage, the problem is that the linkage is too short and i dont know why i have no problem cutting it and making it longer but i just want to know why it doesnt work everything bolted up just fine when i dropped motor in even the torq bracket on the front are bolted up but the linkage is too short
the linkagage on the tranny is pulled all the way out and the shifter is pulled all the way forward and the linkage is fixing to pull out of the rubber mount that is bolted to the car
Re: b swap shift linkage problem
to make sure that i have the right linkage could someone measure their linkage and let me know what the leanth is
thanks for any help
thanks for any help
man that is kinda what i thought so i called the guy who sold it to me and he assured me that it came from a v tec delsol with b16 thats why i want to check the leanth but i dont know what the leanth should be
Well then the guy you bought it from must have got the wrong thing or he got it from someone that told him it was the right linkage because no matter what it should not be that short.If i was you i would just stretch it yourself or buy the right linkage.
On a normal Civic, it's a 4" difference between the DOHC and SOHC engines. I will not guarantee it's the same on a Sol, but you can see.
I suppose you could cut both pieces, tape pieces of a dowel or something and see how long they have to be...
ok, does anybody know how the gears work i pulled the tranny shaft all the way out to get it to reach the linkage anybody know where nuetral is at
redline870
03-23-2011 09:30 AM
spunky424
08-15-2006 08:25 AM
dobbs1027
09-09-2004 05:55 AM
