which computer would run better with this setup?
Wats good guys? Wat do you guys think I got a ls wit gsr pistons and a aluminum flywheel I use the sohc throttle body so which one you think would it run better with a p28 or the ls computer.
Re: which computer would run better with this setup?
ls computer, a p28 is for vtec single cam, your fuel maps would be way off. unless your looking to tune the ecus (chip them) it doesnt matter which you run, (assuming the p75 is obd1 as well
Crazy Honda Guy
First of all, i would upgrade you throttle body, the sohc models are smaller than stock b series!
ok, so basically you have an LS engine with slightly higher compression at 10.0:1 I would just use a obdI p74 or p75, then chip it so the ecu can be tuning for your higher compression.
"IF" you plan to run a vtec head in the future, a p28 is a better choice as it can run both non and vtec model engines once it's chipped and programmed.
