DOHC VTEC engine harness for 96-97 delsol?
I have a 96-97 delsol S and planning to do a dohc vtec motor swap. Wondering what kind of engine harness can u use? Can I use a 96-98 GSR engine harness without any modifications? Or is it possible to use a obd1 under hood engine harness and use a obd2 under dash harness? Do I have to look for a b16 engine harness for 96-97 delsol? Lmk thanks
Seagull Management
Re: DOHC VTEC engine harness for 96-97 delsol?
You can use either '96 - '01 Integra harness, '93 - 97 Del Sol harness or '92 - '95 Civic harness. Ideally if its an OBD2 engine use an OBD2 engine harness, if its an OBD1 engine get an OBD1 engine harness. No matter what harness you use you will need to move a couple of wires around for the IACV.
Right on bro. Thanks. Was wondering if I still have to do some mods on the harness to the ecu? Due to the knock sensor. And what if I use a obd2 to obd1 jumper harness and use a p28 ecu so I don't need to put a knock sensor on? Is that right? Because sohc motor don't come with knock sensors. Did anyone do that befor?
HFpower
11-20-2007 05:26 PM
