h22 civic wiring harness question
Old 08-30-2011, 07:51 AM
patroick67's Avatar
Default h22 civic wiring harness question
Okay I have been told that i can use a h22 wiring harness on a 94 civic dx. I am just trying to figure out is this true or will i need to source a dx wiring harness and use a h22 wiring harness to wire into the civic harness? Just want to make sure before i buy a h22 wiring harness.
Old 08-30-2011, 05:13 PM
Seagull Management
94EG8's Avatar
Default Re: h22 civic wiring harness question
You need to modify the original civic harness. Is it a JDM engine with a cut harness? If so you can get the parts you need from the cut harness.
Old 08-30-2011, 05:44 PM
95EG2's Avatar
u need to wire in the h22 injector harness to the civic harness and wire the resistor block... also have to wire up vtec
Old 08-31-2011, 01:35 AM
patroick67's Avatar
lol actually right now i don't have a harness at all lol i suppose i better start trying to buy a civic harness and a h22 harness argh
Old 08-31-2011, 01:39 AM
aznfreakyguy's Avatar
it probably gonna be easier with the civic harness, i used the h22 for my h2b swap in my teg, but i completely rewired it and tucked it lol
Old 08-31-2011, 10:08 AM
cvcrcr99's Avatar
I am in process of swapping my 99 right now. Wiring is posing problems for me. As long as you have everything labeled on the Civic harness, you should be able to cut and extend to use for the H22. Any sensor plugs needed could be found on the h22 harness.
93hatch_minime
06-02-2013 12:12 AM
turbogsr18
04-28-2008 01:18 PM
turbogsr18
04-28-2008 11:10 AM
civichb97
12-09-2002 01:22 PM
Quick Reply: h22 civic wiring harness question
