em1 steering wheel vibration, searched now desperate
ok 2000 si:
the issue is vibration at throttle, highway speeds and highway speed braking
i checked the front end out, tie rods, ball joints, axles, and bearings. had the wheels rebalanced and then rotated when that didnt work. i did replace the axles because that is the only part i found any play in. which decreased the amount of vibration.
i am thinking:
my new tires are defective. last month i picked up 4 falken 912.
bent rims, lots of potholes here in canada ( bends could be unvisible to naked eye) i do not see any bends tho.
i am pretty stumped on what could be bad.
i am thinking:
Re: em1 steering wheel vibration, searched now desperate
forgot to mention, since the axles i want to try another 100% balanced wheels from a buddys car. pretty much since the axles i need to re diagnose.
i will go for an alignment asap, and i will check over the mounts/ rack tommorrow.
I Also had vibration upon accleration which was my axles. I went through 2 sets of brand new (aftermarket) axle assemblies before I installed a set which were ok.
i swapped axles both sides, and then the drivers side again. there is no play in the axles/cv anymore.
sparxx
04-28-2005 03:09 PM
ice11honda
08-11-2004 05:16 PM
