98 civic power window
i have problem with my driver side window it keeps falling off the track when i roll it all the way down... and when it doesn't fall off the track and i roll it up its off like a mother hugger.. is this a typical problem for 96-00 civic windows??? is there a way to fix it other then buying a new door??
Re: 98 civic power window
Very typical, there is a problem with the run channel, this is the part that is vertical and near the side view mirror. You can replace this part and should help.
Do you have a part number for this? My car has this same problem, and a variety of lubricants are only acting as temporary solutions. I'd rather replace the track and be done with it.
Go to hondaautomotiveparts.com, then look up you car etc. you will then get the part number from there.
civic-si-2000
08-27-2003 11:36 AM
