94 Civic - b16 has VTEC bog
i have a b16a in a 94 civic coupe. i started having problems with my motor and i cant seem to find out what is really is. when my car goes to go in vtec it bogs and i loose my power. i changed my solenoid and that didn't fix the problem. it also seems like i don't have all my power as im accelerating while driving. the rpms jump a little at ideal. a few of my friends told me to check my ecu so i did that and its fine.
Re: b16 problems
Mine was doing the same thing and I changed the plugs and wires. It turned out that one of my wire was shorting out. It would occasionally miss and start bogging at higher rpms.
Re: b16 problems
ok i changer my plugs plug wired and fuel filter and my car still wont go in vtec it bogs when my vtec should kick in. and its sounds like the power is there but my acceleration is shitty. i still cant find out what it is.
Re: b16 problems
ok i changer my plugs plug wired and fuel filter and my car still wont go in vtec it bogs when my vtec should kick in. and its sounds like the power is there but my acceleration is shitty. i still cant find out what it is. if you want i can make a video n show you what its doing.
Re: 94 Civic - b16 has VTEC bog
it starts kinda funny and the rpms bounce a little but when its warmed up it sounds fine sitting there. its only in my higher rpms that im having problems when driving. when the vtec goes to kick in it makes a nasty bog sound and im not getting all the power out of my motor any more. starting off its great untill my rpms are high or i try to clime a hill. all 4 cylinders are good i have good compression good spark. new plugs and wires new fuel filter. my injectors are all good.
check this youtube video out. if you listen right be for i shift around 6k cause it wont go any higher you can hear it. it sounds like ***.
<iframe width="420" height="345" src="http://www.youtube.com/embed/hLhBHndsYlw" frameborder="0" allowfullscreen></iframe>
