GSR TPS question
GSR TPS question
Hey, I have a 95 eg hatch with a gsr swap that I just put in. When I try to maintain a speed of 35 mph or lower it jerks around really bad as if Im letting off the gas pedal and pushing it again. Would you guys think its the TPS? Also if it is the TPS how do I go about fixing it? Do i really need a new TB or can I get a tps from autozone?
Do the skunk 2 IMs come with a TPS?
Re: GSR TPS question
Well i can answer one of your Q's. The Skunk2's IM doesn't come with anything. you'll need all the stuff from your other IM to place on the S2 one. I have a similar problem but your's sounds a tad bit worse than mine. The TPS might be the problem but idk anything about that. hopefully someone can help us out...
http://www.clubintegra.com/board/showthread.php?t=21792
Took (0.21 seconds) in a Google Search "How to check TPS in GSR"
Does the CEL work?
Listen to RonJ@HT. He knows the most out of anyone on here. And is usually right about everything lol.
the check engine bulb is good because it turns on when i turn the key two clicks. im kind of dissapointed in hmotors because swap so far has had bad mounts, possibly tps, my axle shafts are bad too
hey thanks for finding that for me. i will try that asap. i guess i was using the wrong wording in google
