OBD2a D16y7 A/T Engine Harness
I tried posting in the Tech section but didn't get any response so maybe posting here will help.
I was given the harness listed above but could not find anything about pinout regarding the automatic transmission harness. I have searched google and ff-squad but the ecu connector (looks to be a "B" connector, theres no "A", but "C" and "D" are there and it fits into the ecu slots) and the color of the wires do not match what is shown. The harness is from a 96 Civic DX hatchback. There is no "A" ecu plug. From ff-squad's website, it looks to be a "B" plug but when I go to insert it into the "B" spot on a OBD2a B18c ecu (theres no pins there but just wanted to see if it will fit) but it will not go in. I looked at the 96-98 service manual and the colors also do not match up. What is going on here? Any help will be appreciated. Please point me in the right direction as where I can find info on this. Thanks.
Re: OBD2a D16y7 A/T Engine Harness
one of the plug's is from the dash harness . what else's do you need to know ?? sound's like your using a Manuel ecu so why do you need the auto stuff ?? if you need to add wires for vtec,butterflys,knocksensor, why not use them from the auto plug (depin it and add them where needed then just cut out the extra stuff.)
I'm using the given harness as a spare to hook up a b18c but it's just that the wires' color don't match up to the obd2a pinouts so I'm not sure what goes where. I am hooking up to a M/T ecu and have extra ecu plugs but just confuse on what goes where. Only if I could find a diagram showing the colors on the given harness I would be good to go but can't seem to find it anywhere.
egb20v
06-25-2009 12:50 PM
nello a.
12-24-2008 12:20 AM
