98 civic crank no start (no spark?)
I've been trying to fix my car(98 civic dx coupe standard) up after it sat for about 4 months(was driven around the driveway semi-regularly). I had it running about a week ago just idling when it died.
No check engine, it has gas, I just replaced plugs/wires (in correct firing order), replaced the distributor cap/rotor, and tested the main relay (I used a test light and both relays are getting power). I'm definitely getting fuel in the cylinders, the new plugs have gas on them, but I don't think I'm getting spark. I plugged in the spark plug, touched the threads to ground and looked for a spark, I didn't see one.
It seems that the distributor would be the next thing, but is there anything else to consider before going that route? fuses/other tests that I haven't thought of?
Thank you.
Thank you.
Re: 98 civic crank no start (no spark?)
The main relay would not prevent spark if the engine is getting fuel. Does the Blk/Yel wire attached to the coil and ICM have battery voltage? If so, resistance test the coil and have an auto parts store test the ICM.
BUGGYCAR
09-20-2017 07:35 AM
slownlow619
08-29-2013 01:07 AM
94 IntegraLS
21
10-09-2012 02:26 PM
