96 civic with 91 crx hf stock engine -- mixing alternator to ecu wires
what would happen if i mixed the two wires that lead to the ecu: white/yellow and blue?
at the moment it seems my car will only charge for a few mins on a cold start then stop, even when i rev it over 2k rpm my volts never goes above 14.3
my car:
91 honda crx hf stock engine with 96 civic obd2 ohio 170amp high output alternator installed.
my car:
Re: mixing alternator to ecu wires
yeah i mixed the two wires going to the ecu. white/blue and white/yellow. don't know what kinda damage it can do... all i know is my alternator will only charge when i initially start it then stop after a few min.
Re: 96 civic with 91 crx hf stock engine -- mixing alternator to ecu wires
it'll drops down to 12v and my battery light will come on and i'll rev it up a bit but the battery will go up to mid 13v sometimes 13v.
You probably fried the voltage regulator inside the alternator. Have the alternator tested. It's probably bad.
i did have it checked out at o'reilys and it pass all three test that they run 3 times
if the regular of the alternator was fried the alternator should of fail those test they run at auto shops.
i will try the one wire alternator method and see if it output 14+volt charge.
could i have fried my ecu?
even when i turn the ac on my volt will stay the same at around 12.3v even though my eld volt goes from 3.2 to 1.7v (reading done on red/green wire at eld and a ground).
wish i didn't throw my old alternator away
Khrystin
02-21-2019 02:22 PM
West Werks
11-16-2005 12:50 PM
