will the following front LCA fit on my 94 CX eg hatch?
Old 09-03-2011, 11:55 PM
jdmcivic2fast's Avatar
Default will the following front LCA fit on my 94 CX eg hatch?
92-95 civic EX,Dx,Si
96-00 civic dx,ex,hf
94-00 integra ls,gs,gsr,type r
my bushings are worn out on the front lca's want to just replace the whole arms because dont have access to a press. lmk thanks
Old 09-04-2011, 12:05 AM
Information Leafblower
bluebomber's Avatar
Default Re: will the following front LCA fit on my 94 CX eg hatch?
You should look into getting 92-95 EX or Si front LCAs, as these have sway bar mounting points on them if you ever want to add a front sway bar. The CX/DX didn't have a front sway bar, so they don't have them.
Old 09-04-2011, 06:06 AM
tlarimer's Avatar
Yes these are direct bolt in
If I remember correctly, these are different
Old 09-04-2011, 08:56 AM
Master Detailer
98civdx's Avatar
^^ Correct, you cannot run the 96-00 lca without the subframe, and a number of other things.
Old 09-05-2011, 08:00 AM
wat kinda things will it cause my car to do if the bushing on the front lca are worn out?
my car feels a little wobblely when acceleraing from 70-80+mph on the freeway
Old 09-05-2011, 05:54 PM
TheJGB3's Avatar
You're just asking for trouble if you keep driving it this way...get it fixed
Old 09-08-2011, 07:30 AM
ive been driving it this way for years, couldnt figure out wtf it was, ive change new tires, balance a dozen times, new inner and outter tie rods, new shocks/springs, new axles, swap all mounts to good ones, change uca to good ones and still same problem. My boy told me that my bushing are f up on the front lcas so hopefully by changing them will solve this issue.
EMinh1
04-27-2011 09:53 PM
drift2004
08-02-2008 12:25 AM
Forrest Gump 9
09-10-2003 02:33 PM
DerangedEG
17
04-15-2003 07:31 PM
vtecvoodoo
12
04-10-2002 05:19 PM
Quick Reply: will the following front LCA fit on my 94 CX eg hatch?
