92 Civic Si Speedometer not working for the speed but …
Speedometer is not working, but the odometer and trip odometer are ok. I changed the speed sensor just in case and looked at the harness end plug to see if it was burned. It looks good to me. I was thinking on getting the end connector from a junk yard and replace the existing one, but not sure if that should be my next step. Any ideas on next step.
Re: 92 Civic Si Speedometer not working for the speed but …
Its a bad cluster, if the sensor was bad the trip and odometer would not work. You can try resoldering the connections on the back of the cluster or you can just replace it.
Diversion
08-23-2009 10:41 AM
