GSR in an EG - low idle and running Rich.
We pulled my b16 cause it wasnt making compression and put in a gsr motor. It idles like poo if at all. I have the throttle cable pulled a little open so it will idle. It will idle steady at 1500, but not lower.
Checked and cleaned IACV, New plugs. Old plugs were black.
I have a p28 Chipped disabling the O2 sensor.
Im lost.
No CEL.
Im lost.
No CEL.
Re: GSR in an EG running Rich.
Update as of this morning. Disconnected map sensor. Idles smooth now, but obviously CEL came on.
Does this mean I have a vaccuum leak?
Could be a faulty map, try and use a known working map. Running no 02 sensor with a diff map in ecu can make the gsr run rich. Stock intake manifold?
All the map part numbers are the same right?
Im going to rent a gun in a bit. I know the timing was dead on when i got it back, but im going to try to advance it a little to see what happens
you got a vaccum leak, my car was going through that a few weeks ago.
our throttle body might be leaking, i just slapped on a spare one i had and it ran fine idling at 700.
I can find a leak worth a **** though.
I thought the same thing, but i looked up the wiring, and its the right colors.
Thanks for your input guys. Im hopung to get a few maps later. I cleaned mine out and nothing
Ok so i got 2 more map sensors. No change. I noticed the PCV system isnt connected. I cant even see where the line should go on the manifold.
A vacuum leak would cause a high not low idle.
Is the idle speed low only when the engine is hot?
Does the IACV work?
Have you tried adjusting the idle speed?
Regarding running rich, the engine will naturally run rich if the O2 sensor is disabled.
Does the IACV work?
IACV works. Cleaning and swapping it for another one made no difference.
If i adjust idle by the screw all the way up, it will stay running at like 400 rpm.
And i tried to unplug the iacv and set the idle but it wouldnt stay on, so? Should i try it with the map disconnected too? Cause it will idle without the map connected.
Have you measured the resistance of the ECT sensor when the engine is hot?
Have you tested the output voltages of the TPS?
Yes, you are wrong.
Are you saying the idle speed dropped lower when the IACV was unplugged? Find the service manual procedure for adjusting the idle speed of your specific engine.
No, that will not help.
No I have not checked the TPS or ECT yet. The TPS was next in line after i remember to find my HB multimeter.
Ill search for the way to check the ECT
Re: GSR in an EG - low idle and running Rich.
With the MAP sensor plugged in, can you keep the engine running by pressing down the throttle pedal?
Are you sure all the sensor connectors are matched with the correct sensors?
